Feb-Nov23 Leaderboard TEMO2
On test: TEMO·1000 electric outboard motor defies the norm
by Mark Jardine 2 Jan 14:30 UTC
On test: TEMO·1000 electric outboard motor © YachtsandYachting.com
TEMO are an innovative French company who look at solutions in a different way. We'd already taken a close look at the TEMO·450, with its extendable pole, rather than the traditional shape of engine housing at the top, and now we've tried the TEMO·1000, which again defies the norm.
There has been a proliferation of electric outboards on the market, but many follow the traditional shape of an internal combustion engine outboard, housing the battery on the top where the engine would have been.
Electric outboards have the motor at the bottom of the shaft, inline with the propeller, meaning there is no gearing in the shaft itself. With the TEMO·1000 this space is now utilized for the battery, lowering the centre of gravity, and completely eliminating the top housing.
The battery is interchangeable and can be simply lifted out and dropped back into the shaft, while the steering handle can also be stowed inside the shaft, making the TEMO·1000 extremely compact and portable.
Designed for dinghies, and sailing boats up to 8 metres, the 1100W motor offers a static thrust of 28kg, the equivalent of a 3HP traditional outboard.
The retractable tiller also means that the outboard can be fixed centrally on yachts and dinghies which have a rudder or extended when using for both propulsion and steering.
The controls are incredibly simple, with a twist grip providing acceleration, and simply twisting the other way to go astern.
The rotating mounting continues the innovation, able to rotate through a full 360 degrees, and lock the shaft out of the water. With this rotation and it can be stowed conveniently parallel to the transom, freeing up space astern and on deck.
The 949 Wh lithium-ion battery provides 45 minutes of power at full speed, or 1.5 hours at cruising speed, and can be charged via 12, 24 or 220 volts and takes 5 hours 30 minutes to fully recharge. The total weight of the outboard is 15kg, of which 5kg is the battery. The TEMO·1000 is rated IP67 waterproof. Additional batteries are available for long cruises and additional peace of mind. There is a two-year warranty on all products.
Why not join the silent revolution in 2024? The TEMO1000 is emission-free and available now via the team at Marine Products Direct. Find out more at marine-products-direct.com/product/temo-1000-electric-outboard-engine
Easy Med Mooring with the GHOOK from Boatasy
Mooring astern made simple with Boatasy We all know the sailing world is full of strange terminology, and we are about to introduce a new one – Boatasy GHOOK. Posted on 30 Apr
I need to carry an anchor at my next regatta
Help! Where do I start? It's not uncommon these days for class or events to specify the need to carry an anchor on board for safety reasons. In fact, when sailing in tidal waters especially if unsupervised you could say it's always worth carrying one on board. Posted on 27 Mar
MCI appointed Exclusive UK Distributor for Mantus
Mantus Marine offer a full range of performance, quick setting anchors Marine Components International, leading supplier to the UK leisure and commercial marine market, has been appointed as the exclusive UK marine distributor for USA manufacturer of high performance, quick setting anchors Mantus Marine. Posted on 22 Mar
Docking made simple with Boatasy
The gamechanging modular boathook system from Boatasy For any boat owner, whether sailing fully crewed or shorthanded, one of the most challenging parts of any day on the water is the leaving and getting back to the dockside. Posted on 16 Feb
Dripping shaft seal?
Replace your prop shaft seal with Lasdrop Dripless Shaft Seals Dripping shaft seal? It's time to service or maintain your propeller shaft seal! Posted on 12 Dec 2023
Winter maintenance tips
Get ready for winter with these top tips from Marine Products International It's that time of year! Winterisation is now in full swing and around the yard essential maintenance work is being undertaken. Posted on 2 Dec 2023
EchoPilot FLS 3D Gen 4 now compatible with Axiom
Take a look at the new Forward Looking Sonar from Daniamant Calling all explorers and sailors who like to venture away from the conventional harbours and crowded anchorings - you need to learn more about the NEW Forward Looking Sonar from Daniamant. Posted on 4 Sep 2023
Say goodbye to your old traditional boat hook
Compact lightweight boat hook from MCI Say goodbye to your old traditional boat hook that corrodes and occupies significant space when not in use and say hello to the future in boat hook design, the Revolve-Tec Rollable Boat Hook available from Marine Components International. Posted on 20 Jul 2023
On Test: TEMO-450 portable electric outboard
Lightweight, IP67 waterproof, extendable pole provides a whole new option for your dinghy The TEMO-450 is a portable electric powered outboard, which differs substantially from other outboards on the market. Posted on 6 Jun 2023
Marine Products Direct 2023 - Calypso FOOTER
